66 Pages«<2122232425>»
JAIRODJ
#441 Posted : Saturday, January 27, 2018 5:15:30 PM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hello, elgarf
I produce a music program with video clips.
And now I use a powershell script to get the title and the artist of the video and this data is sent to a xaml graphic, it is practically autonomous since in addition to obtaining the titles the script is programmed to activate the overlay (any number) to a certain time of beginning the video and before finalizing the video.
The situation or the difficulty is that it opens a console window and loads a lot of information that comes from the data that must be obtained to keep the information updated.
I consult if a function like this can be added to UTC, in the Text Field window, to handle it in a visual way with interfaces that are easier to use.
kevev
#442 Posted : Saturday, January 27, 2018 6:30:37 PM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
Looking for a way to do select entries from multiple list widgets without populating xaml overlay until after pressing a button widget. It does not look professional when entering data in the overlay one entry at at time. Is this possible?
chezter
#443 Posted : Monday, January 29, 2018 3:52:49 AM(UTC)
chezter
elgarf wrote:
@chezter, hmmm... I don't see nothing bad. You also can look into windows event log, there should be event connected with UTC, maybe it show error more clear.
There's nothing, I do not know what it can be, I'm in w10.
Eh updated graphics drivers, framework etc.
It just stops working, it's more I thought it was saturation and just leave the scoreboard active, nothing more. But the same closes automatically.
The process reduces memory varies between 300 to 1000
chezter attached the following image(s):
elgarf
#444 Posted : Monday, January 29, 2018 7:27:02 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
1gb of RAM is slightly big. Mine eats about 50-100mb with my volleyball controller. Wait until next version with build date, it will be soon available, I'm working on one key shortcuts (for example 1, or just Z or etc.). It almost finished.
Maybe you using old version, or there is problem with connection of vmix and utc.
@JAIRODJ, are you taking info about tracks from vmix or from external software? I'm trying to minimize data transfer, and less queries to vmix.
@kevev, at this time you can make it through proxy xaml title, which will be invisible for anyone, and scripting (if you want I'll make an example). I'll think to make data transfer pause. Maybe for sports it not very actual.
JAIRODJ
#445 Posted : Monday, January 29, 2018 10:53:27 AM(UTC)
JAIRODJ
Basically the script gets the data through the localhost of vmix
"http://localhost:8088/API/"
After selecting the title data of the entry with the video list
List - Bruno Mars - Liquid store blues
$title_name = Liquid store blues
$title_artist = Bruno Mars
Send the information to vmix with API commands
"http://localhost:8088/API/?Function=SetText&Input=$input_no&SelectedName=$title_name&Value="
"http://localhost:8088/API/?Function=SetText&Input=$input_no&SelectedName=$title_artist&Value="
The activation of the overlay depends on the position of the video when reproduced (10 seconds after the video starts and 20 seconds before ending the video)
"http://localhost:8088/API/?Function=OverlayInput$ovin&Input=$input_no"
"http://localhost:8088/API/?Function=OverlayInput$ovout&Input=$input_no"
elgarf
#446 Posted : Tuesday, January 30, 2018 6:49:27 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, at this time there is no string manipulation functions in UTC. Sooo... you can achieve input title, but can't split it into parts. I can add such capabilities in later updates.
Btw, there is new version.
I made one-key shortcuts more user-friendly, so when you write something into TextField/Score/etc shortcuts like [Z] or [1] will not work. You should drop focus from widgets by pressing [Return] or clicking outside widget. Btw, [Return] or [Space] shortcuts may work weird =)
Also selection border doesn't stop if you move your mouse outside of the UTC window.
Direct download link
JAIRODJ
#447 Posted : Tuesday, January 30, 2018 2:11:40 PM(UTC)
JAIRODJ
Thanks @elgarf for your response.
Hopefully in the future you can help us with this self-titled option
regards
kevev
#448 Posted : Wednesday, January 31, 2018 1:13:12 PM(UTC)
kevev
Yes an example would be great. Also can we have my request officially supported in a later version? It would be easier than using a proxy xaml. :)
One more request: I think you answered me on this one previously, but I have not seen the feature added. For the Score widget, it would be nice if we could manually set the score buttons values manually as US Football uses +1, +2, +3, +6. Also could we have -1, -2, -3, -6 buttons? Can you please please please add this option? Or maybe just duplicate the Score widget for football and maybe other sports in the menu of widget options? :)
https://en.wikipedia.org.../American_football_rules
Thank You so very much for UTC! It has saved us from headaches.
elgarf
#449 Posted : Friday, February 2, 2018 2:06:22 AM(UTC)
elgarf
Russian Federation
I've updated UTC with Score styles (basic/basketball/american football) and some functions for string manipulation.
@kevev, download new version, please. Also there is example to using proxy title.
@JAIRODJ, I can make sample for auto overlay music titles, but it's not so time accurate =) you can trigger overlay at +-5 sec time from your desired time point.
First post
JAIRODJ
#450 Posted : Friday, February 2, 2018 9:52:04 AM(UTC)
JAIRODJ
Hello, if you would help an example of how to use the new functions for self-title in music clips.
Thank you
tkachuk.alex
#451 Posted : Friday, February 2, 2018 10:11:09 AM(UTC)
tkachuk.alex
Ukraine
Hi!
Have a problem. I use UTC on laptop connecting via ethernet to vmix PC. But few days ago it suddenly close and now don't work.
When I try to open UTC, it started and closed after 30-40 sec. The IP and PORT field are empty. I try to enter valid IP and Port and press Update State but nothing happens, and UTC closed after 30-40 sec. I try to create button or Text field, anything, but nothing happens, and UTC closeed.
Maybe I need some Windows components to reinstall, or something else? Please help
elgarf
#452 Posted : Friday, February 2, 2018 10:48:54 AM(UTC)
elgarf
Russian Federation
@tkachuk.alex, try to remove vMix UTC folder into your documents folder. If log is enabled, show me your log file.
tkachuk.alex
#453 Posted: : Friday, February 2, 2018 11:47:03 AM(UTC)
tkachuk.alex
Ukraine
Thx. I check log, and there was a mistake at ip adrees saved before. There was "," instead ".". So I fix this parametr at xml, and everything work perfectly.
But, some information for you. I change IP at last game, and make this mistake in UTC, I remember this, after State update, I saw this and then I fix it at UTC, and UTC work great. But somehow at xml he saved ip with mistake.
chococrispis35
#454 Posted : Monday, February 5, 2018 6:16:51 AM(UTC)
chococrispis35
I'm using UTC for baseball and I've created 3 buttons for balls, strikes and outs, how can I reset balls and strikes in each out, and the fourth ball resets strikes?
elgarf
#455 Posted : Monday, February 5, 2018 7:26:00 AM(UTC)
elgarf
Russian Federation
@chococrispis35, You can enable reset shortcut for strikes and balls score widgets, name them and make button with two ExecLink commands.
thanks 1 user thanked elgarf for this useful post.
chococrispis35 on 2/6/2018(UTC)
chezter
#456 Posted : Monday, February 5, 2018 8:12:20 PM(UTC)
chezter
I still have the error, it closes only after a few minutes that goes well.
I have come to the events of errors and I have caught this.
elgarf
#457 Posted : Monday, February 5, 2018 8:33:22 PM(UTC)
elgarf
Russian Federation
@chezter, There is ".Net Runtime" error right below your, occured at the same time. It should help a little more.
chezter
#458 Posted : Monday, February 5, 2018 11:54:59 PM(UTC)
chezter
show this
error 2.png (16kb) downloaded 9 time(s).
elgarf
#459 Posted : Tuesday, February 6, 2018 12:07:22 AM(UTC)
elgarf
Russian Federation
Hmmm... What about "Details" tab?
kevev
#460 Posted : Tuesday, February 6, 2018 5:42:59 PM(UTC)
kevev
First post
Thank You elgarf!!!!! You are my hero! The new Score styles work great! Also thank you for the proxy example.
Another request I have, if possible, is a list widget that handles images and a button widget that handles images. This would allow for quickly changing an image in an overlay.
I am still having the issue where after using UTC for more than 30 minutes it gets slugish. Clicking buttons and lists take a very log time to react. This gets worse as time goes by.
I am wondering if it is the logging that is causing this issue. I have "Enable Log" un-checked and UTC still creates logs. They get very big over time(over 20MB). Can you verify that
un-checking the box disables all logging?
Guest (15)
