Feature Requests
More Audio channels in the Master file
With Live shows many people accept what they are given and know Audio won't be perfect. When you then use the same for VOD there is a different expectation. It would be great to have the live Audio saved in channels 1&2 and other inputs stored in subsequent audio channels. This way programs like Adobe Premier has them synced and it is a matter of mixing them, removing what is not needed. If they are saved in separate files there is a lot more time need to sync the audio. It might even be a solution to allow multicorder to save different inputs to different videos as it would make it very easy to sync everything then.
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Feature Requests
