Render Time Hovering at 72 ms with no cameras connected
Joined: 2/2/2018(UTC) Posts: 4 Location: Baton Rouge, LA
I'm trying to kill down the render time on our system. We have a 4 camera system, the computer has no inputs on it right now besides two NDI inputs on the same computer and the program that broadcasts them isn't running. Meanwhile, the render time is staying around 72 ms. System Specs
Windows 10 Pro x64 Core i7-7700K 16 GB Ram Nvidia Geforce 1080 Ti 4 1080p Camera through SDI capture card 2 NDI inputs through NewBlue Titler Live Right now as mentioned neither of those are active and the render time is hovering around 72 ms. I've followed all recommendations on this page: https://www.vmix.com/kno...2/optimising-performance
Joined: 4/18/2016(UTC) Posts: 223 Location: United Kingdom
Thanks: 33 times Was thanked: 37 time(s) in 31 post(s)
Have you looked at task manager/services to see what's running in the background?
Thanks: 9 times Was thanked: 45 time(s) in 38 post(s)
Is the vMix performance tab is settings showing the nVideo card as the one in use?
NHT wrote:Have you looked at task manager/services to see what's running in the background? I did. It was the only program using the card, besides one or two others. See attached image. Image avaliable via link: Task Manager.png
AlanZ wrote:Is the vMix performance tab is settings showing the nVideo card as the one in use? Yes, take a look at this image, I set them earlier. I attached the image to the post. MackK1 attached the following image(s):  Performance.PNG (32kb) downloaded 0 time(s).You cannot view/download attachments. Try to login or register.
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
Every time I see this problem, My goto is to stop the NVidia Share processes (as well as any shadowplay if you are on an older version). If you uninstall nVidia GeForce Experience you essentially do the same thing. Have you looked at that as a possible cause?
EDIT: I see vMix has included this into their official documentation as a fix, sorry if you have done this already. But there are a lot of sneaky background processes that may need another review.
MackK1 wrote:NHT wrote:Have you looked at task manager/services to see what's running in the background? I did. It was the only program using the card, besides one or two others. See attached image. Image avaliable via link: Task Manager.png Maybe try killing off each process that's using the GPU systematically and watching the render time?
 1 user thanked NHT for this useful post.
NHT wrote:MackK1 wrote:NHT wrote:Have you looked at task manager/services to see what's running in the background? I did. It was the only program using the card, besides one or two others. See attached image. Image avaliable via link: Task Manager.png Maybe try killing off each process that's using the GPU systematically and watching the render time? I did, I figured out which one it was. Thanks. Remote Access didn't look like it was the cause at first, but I killed it and it went down to a 4 ms render time.
MackK1 wrote:NHT wrote:MackK1 wrote:NHT wrote:Have you looked at task manager/services to see what's running in the background? I did. It was the only program using the card, besides one or two others. See attached image. Image avaliable via link: Task Manager.png Maybe try killing off each process that's using the GPU systematically and watching the render time? I did, I figured out which one it was. Thanks. Remote Access didn't look like it was the cause at first, but I killed it and it went down to a 4 ms render time. Excellent, glad you got it sorted.
