Hardware Compatibility
vMix doesn't see my Sony IP camera
Thanks: 28 times Was thanked: 3 time(s) in 3 post(s)
Hi all,
I am using Blue Iris for Church streaming with one Sony SNC-RZ30 IP camera, I have selected the camera type and then it works perfect without latency or freezing. And I can control it completely. But because Blue Iris has no mixing options, I have tried vMix.
Unfortunately vMix seems not to support my camera, why is that? Most simple programs like H264webcam and XPwebcam do support mjpeg camera's.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
Welcome to the vMix Forum. Glad you're giving vMix a try. To add an IP cam as an Input, click Add Input, select Stream, then enter the URL of the camera. Should be something like Sony SNC-RZ30N http://IPADDRESS/oneshotimage.jpg Sony SNC-RZ30N http://IPADDRESS/image Sony SNC-RZ30N http://IPADDRESS/img/mjpeg.cgi Sony SNC-RZ30P http://IPADDRESS/oneshotimage.jpg Sony SNC-RZ30P http://IPADDRESS/img/mjpeg.cgi Sony SNC-RZ30P http://IPADDRESS/image Sony SNC-RZ50N http://IPADDRESS/oneshotimage.jpg These are from this site: http://www.camera-sdk.co...ony-ip-camera-onvif.htmlLet us know how it goes. - Tom
Thanks Tom.
I tried all entries with udp and tcp (camera doesn't support RTSP), but vMix shows: Invalid port (even when I add the port number to the IP address) And how do I insert the username and password of the camera in the url? (unauthorized view is disabled of course)
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
Should it not be someting like: rtsp://ip_address/media/video1
The camera doesn't support RTSP.
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
vMix doesn't support mjpeg camera's like the Sony SNC-RZ30 and RZ25. You can use a directshow filter like Alax, see here.
 1 user thanked JW for this useful post.
