rowby
#1 Posted : Tuesday, January 23, 2018 10:58:33 AM(UTC)
rowby
Hello Everyone,
I have created a title with my logo using the title editor. The top part of the image is a solid graphic, the bottom part has an alpha channel.
How can I use a trigger to add that title as an overlay to a Web Browser input that I have already created.
I want the that specific title to appear at the same time as the input appears.
I see this example in the vMix Knowledgebase, but don't see where I can specify the specific title that I have created.
https://www.vmix.com/hel.../index.htm?Triggers.html
BTW I don't think I want to do the logo as a Multiview layer in my Web Browser input, because I need to zoom in on the browser -- and I'm finding if I zoom in on the browser using Multiview"Position", my logo also zooms in (or out).
Any suggestions?
Rowby
#2 Posted : Tuesday, January 23, 2018 12:39:44 PM(UTC)
@ rowby
The "Trigger" set-up as listed should work, only choose your "Input" from the dropdown menu.
The "OnOverlayInput1Out" function does not require you to choose the Input.
If using the MultiView Feature, set-up both Inputs as MultiView Overlays on a Blank Colour Input, that way Positioning and Zoom are independent of each other.
rowby on 1/23/2018(UTC)
rowby
#3 Posted : Tuesday, January 23, 2018 2:18:32 PM(UTC)
rowby
Thanks IceStream
Perfect! Your explanation lets me resize my web browser -- without affecting my logo.
And what is the best way to use a trigger to have the keyboard automatically enabled for that web browser, instead of having to right click the browse for that selectable submenu....? My below setup doesn't seem to work to enable keyboard navigation with Web Browser Input.....
Rowby
rowby attached the following image(s):
keyboard trigger.png (61kb) downloaded 19 time(s).
#4 Posted : Wednesday, January 24, 2018 9:40:07 AM(UTC)
@ rowby
Looks like you have enabled the keyboard on the wrong Input...
rowby
#5 Posted : Wednesday, January 24, 2018 3:14:29 PM(UTC)
rowby
Thanks, Ice, That fixed it!
Rowby
