waldron18
#1 Posted : Saturday, January 20, 2018 10:46:49 PM(UTC)
waldron18
Hi there
I'm wondering if it's ok to use both NTSC and PAL camera inputs? Does it really matter?
I have my production set to PAL 1080P 30 and I want to bring in both PAL and NTSC inputs. Will vMix just work it's magic and make it work? Or do I not even need to worry about it and just put in any camera at 30fps?
Cheers
zenvideo
#2 Posted : Sunday, January 21, 2018 5:19:43 AM(UTC)
zenvideo
Aside from the fact that PAL is 25 and not 30, yes, you can mix-&-match PAL/NTSC source frame-rates in vMix and it will come out the other end at whatever the profile is set to. Obviously it's better to keep the same frame-rate from end to end throughout the production, since any conversion (in vMix) will not be as sophisticated as a full-blown broadcast standards converter.
