weiyunMMW
#1 Posted : Saturday, January 20, 2018 12:57:39 AM(UTC)
weiyunMMW
hi, i'm facing a problem to stream custom RTMP.
it come out with error:
ffmpeg started on 2018-01-18 at 19:11:14
Report written to "C:\ProgramData\vMix\streaming\streaming 20180118-191113.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg2.exe" -report -rtbufsize 256M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1000k -g:v 50 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 1000k -maxrate:v 1100k -codec:a aac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/20.0.0.46)" -f flv rtmp://13.250.153.31:1935/5-15-SaifuddinTest
ffmpeg version 3.3.git Copyright (c) 2000-2017 the FFmpeg developers
built with gcc 4.8.1 (rev2, Built by MinGW-W64 project)
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-nvenc --cpu=i686
Guessed Channel Layout for Input Stream #0.1 : stereo
Input #0, dshow, from 'video=vMix Video YV12:audio=vMix Audio':
Duration: N/A, start: 2666561.301000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 25 fps, 25 tbr, 10000k tbn, 10000k tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, stereo, s16, 1536 kb/s
[tcp @ 06720d40] TCP Buffer has been set to 2820096 bytes
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (71% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (73% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (76% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (88% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (90% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (91% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (93% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (95% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (96% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (97% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (98% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (99% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (100% of size: 256000000 [rtbufsize parameter])! frame dropped!
May i know how to fix it?
thanks
sinc747
#2 Posted : Saturday, January 20, 2018 1:31:33 AM(UTC)
sinc747
Was thanked: 201 time(s) in 167 post(s)
That normally means that you are trying to stream faster than your available upload internet bandwidth.
Check your internet upload speed and adjust your streaming bit rate to 50% to 75% of your available upload bandwidth.
- Tom
weiyunMMW on 1/20/2018(UTC)
weiyunMMW
#3 Posted : Saturday, January 20, 2018 1:48:38 AM(UTC)
weiyunMMW
hi Tom.
Thanks for replying my msg. I checked my upload speed is 78mbps, but my stream is video birate 1024kb....
Do you know why it still not working to me?
thanks.
#4 Posted : Saturday, January 20, 2018 2:06:20 AM(UTC)
Was thanked: 4561 time(s) in 1580 post(s)
The key thing is to look at the full log file in C:\ProgramData\vMix\streaming and see what it says at the very end.
The buffer message from the beginning of the log just means it hasn't connected yet, which may mean the RTMP url is incorrect or your firewall is blocking the connection.
https://www.vmix.com/kno...ng-ffmpeg-streaming-logs
weiyunMMW
#5 Posted : Saturday, January 20, 2018 2:41:40 AM(UTC)
weiyunMMW
hi.
i tried to turn off my firewall, but it doesn't make a different.
ffmpeg started on 2018-01-18 at 22:27:28
Report written to "C:\ProgramData\vMix\streaming\streaming 20180118-222727.log"
Command line:
"C:\\Program Files (x86)\\vMix\\streaming\\ffmpeg.exe" -report -rtbufsize 256M -f dshow -i "video=vMix Video YV12:audio=vMix Audio" -codec:v libx264 -s:v 1280x720 -pix_fmt:v yuv420p -threads 4 -bufsize:v 1000k -g:v 50 -preset:v veryfast -profile:v baseline -level:v 3.1 -b:v 1000k -maxrate:v 1100k -codec:a libfaac -b:a 128k -strict -2 -rtmp_flashver "FMLE/3.0 (compatible; vMix/20.0.0.46)" -f flv rtmp://13.229.20.95:1935/5-15-SaifuddinTest
ffmpeg version 2.8.git Copyright (c) 2000-2015 the FFmpeg developers
configuration: --enable-gpl --enable-version3 --enable-libx264 --enable-zlib --enable-libfaac --enable-nonfree --cpu=i686 --enable-nvenc
libavutil 55. 2.100 / 55. 2.100
libavcodec 57. 3.100 / 57. 3.100
libavformat 57. 2.100 / 57. 2.100
libavdevice 57. 0.100 / 57. 0.100
libavfilter 6. 9.100 / 6. 9.100
libswscale 4. 0.100 / 4. 0.100
libswresample 2. 0.100 / 2. 0.100
libpostproc 54. 0.100 / 54. 0.100
Duration: N/A, start: 2678335.159000, bitrate: 1536 kb/s
Stream #0:0: Video: rawvideo (YV12 / 0x32315659), yuv420p, 1280x720, 25 tbr, 10000k tbn, 25 tbc
Stream #0:1: Audio: pcm_s16le, 48000 Hz, 2 channels, s16, 1536 kb/s
[tcp @ 0664edc0] TCP Buffer has been set to 2820096 bytes
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (63% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (65% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (66% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (68% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (70% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (71% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (73% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (75% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (76% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (77% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (78% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (79% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (80% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (81% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (82% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (83% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (84% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (85% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (86% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (87% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (88% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (89% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (90% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (91% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (92% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (93% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (94% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (95% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (96% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (97% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (98% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (99% of size: 256000000 [rtbufsize parameter])! frame dropped!
[dshow @ 012482c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (100% of size: 256000000 [rtbufsize parameter])! frame dropped!
#6 Posted : Saturday, January 20, 2018 3:27:23 AM(UTC)
Just ran a test to that address here. The URL or Stream Key is incorrect so check with the provider what you need to enter.
It may require a username and password which is set by using the Advanced button in Streaming Settings in vMix.
weiyunMMW
#7 Posted : Saturday, January 20, 2018 4:58:56 AM(UTC)
weiyunMMW
Hi, the streaming key was deleted by me after the test was fail. i think that is why the stream key is incorrect to you.
i checked the advance button in streaming settings in Vmix, which user agent is FMLE. im not running FMLE for streaming.
#8 Posted : Saturday, January 20, 2018 5:00:54 AM(UTC)
Please create a new stream and continue to stream until an error occurs.
The stream logs posted so far only show part of the stream, as if it was stopped before we got the error message.
In any case it does look like the stream details are incorrect.
weiyunMMW
#9 Posted : Saturday, January 20, 2018 6:37:31 AM(UTC)
weiyunMMW
Hi, if i keep streaming for couple of hours just showing "[dshow @ 049480c0] real-time buffer [vMix Video YV12] [video input] too full or near too full (100% of size: 256000000 [rtbufsize parameter])! frame dropped! " and no error pop out, what should i do for next?
Thanks.
