yapandy
#1 Posted : Wednesday, January 10, 2018 7:14:59 PM(UTC)
yapandy
I don´t know why this feature isn´t there already. Please guys, give us this option.
Thanks in advance!
Barney Box Lane
#2 Posted : Thursday, January 11, 2018 11:46:53 AM(UTC)
Barney Box Lane
Was thanked: 33 time(s) in 29 post(s)
hi, you need vtask it's another software that connects to vmix and allows you to do scheduling across multiple inputs using multiple commands and to a schedule
yapandy
#3 Posted : Thursday, January 11, 2018 8:53:43 PM(UTC)
yapandy
Thanks For the tip!
The problem with individual 3rd party developers is that one day they get tired of developing their little experiment and then you are left with nothing. Vmix developers, get it done please. Thanks.
Lennart
#4 Posted : Wednesday, January 17, 2018 8:50:11 AM(UTC)
Lennart
Denmark
Was thanked: 16 time(s) in 15 post(s)
As Barney says you should look into vTask. I'm using it to run a 24/7/365 tv channel.
The vMix guys have stated in the past that it's not within the scope of vMix to use it as a playout server, so I wouldn't expect them to start working on it any time soon.
yapandy
#5 Posted : Wednesday, January 17, 2018 9:24:44 AM(UTC)
yapandy
Ok. Thanks for your input as well, Lennart.
Peter B
#6 Posted : Wednesday, January 17, 2018 5:12:48 PM(UTC)
Peter B
I would think that having the playlist events triggered by the PC clock would make a dandy automation system.
The people who need this would be fine buying the 4K version.
Barney Box Lane
#7 Posted : Friday, January 19, 2018 6:27:55 AM(UTC)
Barney Box Lane
YapAndy I know what you mean with a lot of programmes like that but I think Vtask is taken very seriously purely because he's taken so much time doing tutorials and updated versions. You might find it helps as an isolated programme then you can even run it off another computer on the network and have more control over it - there might be some hidden plus points. You can essentially class it as another window in vmix that can be thrown on another computer so it might help with management in the long run.
