Hardware Compatibility
Connect Spark - no audio (solved)
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
Hi
I have a Connect spark (connected using the HXdriver) and in vmix im getting no audio. If I open the NDI studio monitor I have audio coming in but when I select the spark as an input in vmix there is no audio. If I change that same input, and therefore have the same audio settings, to the mobile NDI app, I then have audio. Any ideas on where im going wrong please?
Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
did you get it worked out?
Hi Rob,
I think it was from setting it up and bringing it in for the first time with an already opened vmix project (it was also the only ndi source that showed up at the time) I just rebooted vmix and all was good.
