Joined: 10/20/2016(UTC) Posts: 57 Location: Virginia-USA
Thanks: 5 times Was thanked: 6 time(s) in 4 post(s)
I was curious as to what the max depth is for multiview? I believe it to be 2 levels, but not sure why. I have an input of transparent color (base) I have two other inputs of games to bring in based on what is being played (G1 and G2) I then have an input acting as a stage for multiple sets of players (Stage1) Multivew = MV Stage1 --MV1 - base -----MV1 - G1 player1 -----MV2 - G2 player1 --MV2 - base2 -----MV1 - G1 player2 -----MV2 - G2 player2 The tree above, both G1 and G2 of both base are not visible unless they are the Main. When the players switches games, I would like to create a shortcut that disables the MV at index 1 and another that enables the MV at index 2. Currently I have to manually change the input source when we change games in the middle of a stream, times 5. I would like to streamline this a bit. I have 5 stages that I cycle through that show all the players, with one being the largest screen. Attached is stage 1. Each player has their own stage. Thanks, r5dad attached the following image(s):  stage1.PNG (2,009kb) downloaded 17 time(s).You cannot view/download attachments. Try to login or register.
