radamo
#1 Posted : Saturday, January 13, 2018 8:34:18 AM(UTC)
radamo
I think i am one of the first to get the new io 4K pus aja in thunderbolt 3. At this moment, i can only get two input SDI and two output SDI in the aja controlpanel. And in the Aja multi-channel config, i can choose 3 input or 4 input SDI but it does not change anything in the controlpanel.
In vmix I don't see any aja input option in the add input camera tab.
Any idea ? Anyone also with Aja IO thunderbolt 3 here ?
Bossman42
#2 Posted : Saturday, January 13, 2018 2:49:37 PM(UTC)
Bossman42
I’ve had a similar issue with an AJA card today. Vmix will only see one of the three SDI inputs of the card.
radamo
#3 Posted : Saturday, January 13, 2018 4:13:49 PM(UTC)
radamo
I can't any see aja input (not even 1). Adobe premiere is able to ingest video through the aja.
Olivier
Bossman42
#4 Posted : Saturday, January 13, 2018 4:40:28 PM(UTC)
Bossman42
Weird..
radamo
#5 Posted : Sunday, January 14, 2018 3:10:58 AM(UTC)
radamo
I got an answer from Aja support, here it is :
Hello Olivier,
We tested vMix (20.0.046) here with the Io4K-Plus and are getting the same results.
We spoke with the Io4K-Plus Product Manager about this.
It appears that vMix does not currently support the Io4K-Plus.
However they will soon, they are in the process of developing a plug-in for it.
So, be aware that, at this time, Aja io 4K plus does not work with vmix.
Olivier
thanks 1 user thanked radamo for this useful post.
niemi on 1/14/2018(UTC)
hellokitty
#6 Posted : Tuesday, January 16, 2018 12:32:10 AM(UTC)
hellokitty
i have been useing a Kona 4 in a thunderbolt 2 and 3 enclosures for close to 2 years. you can use all 4 sdi as long as they are the same. it is a cheeper solution i bought mine used ebay.
Guest (4)
Similar Topics
AJA Io 4k Plus - what ports that vMix can use? (General Discussion)
by Paul CVP 11/6/2024 9:50:28 AM(UTC)
Aja Io 4k Plus Audio Output question (Hardware Compatibility)
by Burnmaester 1/21/2021 5:16:57 AM(UTC)
Output with AJA io 4k plus (Hardware Compatibility)
by VJB 9/28/2020 12:03:13 AM(UTC)
AJA IO 4K Plus HDMI Out (Hardware Compatibility)
by chrisdurkee 11/2/2018 11:11:21 AM(UTC)
