Hi, Is it possible to flip the ticker scrolling direction? i.e. scrolling from the left hand side to the right? - for supporting laguages like Hebrew, Arabic? Thanks, Sharon.
Thanks: 1 times Was thanked: 9 time(s) in 6 post(s)
I can explain how to reverse the scroll, but I don't have any R2L languages installed, so on my computer, it displays L2R text from the last word to the first. Open c:\Program Files\vMix\Titles\TickerHD.xaml in Notepad Since you're dealing with a file in the "Program Files" folder, you'll need to run Notepad as an Administrator. Locate the "DoubleAnimation" tag (about 11 lines down). Within that tag, you'll see: Change this to read: Save your changes. Now, your ticker will be reversed. Jon
 4 users thanked jwolthuis for this useful post.
 1 user thanked fakory.peter@gmail.com for this useful post.
jwolthuis Thanks for the instructions. Is it also possible for revers direction also for the GT ticker? I open the zip file but the code is different. Thank you
Joined: 3/7/2012(UTC) Posts: 2,691  Location: Canada Thanks: 33 times Was thanked: 514 time(s) in 482 post(s)
@ eyal.m
The GT Ticker direction and speed can be changed in the Title Editor. Right click the Input===> Select Title Editor===> click the clock icon
