spencerm24
#1 Posted : Tuesday, January 9, 2018 3:31:32 PM(UTC)
spencerm24
I've been trying to get my system configured, but am running into an issue with the outputs of the Behringer UMC1820. I got the inputs to work on the ASIO driver, and vMix sees all 8 XLR inputs.
Trying to get the audio outputs, I want a Main L and R as well as both Aux's to be output on the first 4 1/4" connectors on the UMC1820.
My problem is that unlike the inputs, where you select ASIO driver, and then select the channel you want (1, 2, 1+2 etc) the output doesn't let you select what channel to put these onto.
How do I get the UMC configured with vMix to get these 4 outputs to come out of the 1/4" connectors on the UMC?
