External Output issues (Tested: 9.1.0.33-34)
Joined: 11/14/2012(UTC) Posts: 414  Location: Finland Thanks: 272 times Was thanked: 40 time(s) in 38 post(s)
Hello! Got today "HD-ready" Tv with HDMI in. This Tv set support only SD and 720P. All went OK and I got it working 720P. After quitting vMix and restart I got this: "DeckLink Välillä olevien suodattimien yhdistelmää ei löydetty yhteyden muodostamiseen." Meaning something like this: "DeckLink: Combination of filters could't be found to accomplish connection" It worked with these Output settings: System: PAL 50i or 25p Output: 1280x720 It seems that it still works in 1080P (no error message), but I can't get it output 720P any more. - - - Here is an another issue I already reported: Can't stop External output once it has been activated (at least Decklink). It seems to happen when vMix Video Device is NOT activated in External Output settings. Kind regards, J. Tervo
Power to Change 2013 (Turn CC / English subtitles on): https://www.youtube.com/...Y_yVR3q4FN1lL8iky5Sgynpj
With 720p try 50 or 60 frames per second, any "hd ready" tv should support that, it's part of the hdmi specs.
Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
The issue that caused video not to output with Decklink was that I had in Performance setting wrong output type selected (RGB32). Thanks Martin for fixing External Output stop -bug. Kind regards, J. Tervo
