angelo78
#1 Posted : Wednesday, April 6, 2011 10:29:31 AM(UTC)
angelo78
hello martin,
i reformatted my cpu and installed the latest version of vmix. now i got some problems, it won't play my .avi, .mkv, .mp4 files. before i reformatted my cpu, vmix used to play those video files. what do i have to do to be able to play again those video files in vmix? thanks!
angelo
tony marone
#2 Posted : Wednesday, April 6, 2011 1:03:45 PM(UTC)
tony marone
Hi Angelo,
If memory serves me correctly, you probably need to install ffmpeg and the haali media splitter. Not sure if this is al you need, but it sure solved my problems.
Hope this helps,
Tony
angelo78
#3 Posted : Thursday, April 7, 2011 7:43:08 AM(UTC)
angelo78
hello tony,
thanks for your reply. now i can play my video files again. once again thank you.
angelo
Similar Topics
vMix AVI vs MKV with vMix Video Codec (General Discussion)
by computersrock 3/14/2023 5:15:51 AM(UTC)
How to convert or open or edit recordings using Vmix Video Codec (General Discussion)
by InspoHub 3/3/2023 12:10:16 AM(UTC)
Newtek video codec on MXF container :) (Feature Requests)
by PFBM 5/23/2017 4:12:14 PM(UTC)
What is the best video codec to use? (General Discussion)
by bfilmnor 8/11/2015 7:12:03 PM(UTC)
Ut Video Codec Suite (General Discussion)
by Guest 6/16/2012 10:04:38 AM(UTC)
x264 video codec and AAC audio codec recording (General Discussion)
by Guest 8/31/2010 5:55:19 PM(UTC)
