3 Pages<123
#41 Posted : Friday, June 7, 2013 7:18:18 AM(UTC)
Was thanked: 4719 time(s) in 1617 post(s)
There's a small update below for anyone having issues with the the Teradek Cube with vMix 9:
http://forums.vmix.com.a....aspx?g=posts&t=1019
I would be interested in hearing your feedback.
ovinas
#42 Posted : Monday, June 10, 2013 2:44:18 PM(UTC)
ovinas
With the update to 9.1.0.33 I'm loosing many resolutions for the external output. For example 640x360 isn't available. Reinstalled 9.1.0.31 and all resolutions are back again.
#43 Posted : Monday, June 10, 2013 10:58:43 PM(UTC)
Ovinas,
Thanks for pointing that out.
I have updated the download to 9.1.0.34
http://www.vmix.com.au/download/vmix9.exe
Thanks,
jet
#44 Posted : Tuesday, June 11, 2013 11:42:14 AM(UTC)
jet
Was thanked: 23 time(s) in 21 post(s)
Hello!
Can't stop External output once it has been activated (at least Decklink).
It seems to happen when vMix Video Device is NOT activated in External Output settings.
Kind regards,
J. Tervo
Power to Change 2013 (Turn CC / English subtitles on):
https://www.youtube.com/...Y_yVR3q4FN1lL8iky5Sgynpj
fullerfilms
#45 Posted : Tuesday, June 11, 2013 4:08:57 PM(UTC)
fullerfilms
Hi. We're planning to buy 3 Teradek Cubes this week, for streaming cameras to vMix. It's for broadcasting a live event happening at the end of June. Is this a safe plan at this stage in the software? I do have a couple weeks for testing before the event. I would like to stream 2 x 720p 5mbps feeds to vMix using a separate wireless AP for each Teradek. There will also be 2 more video inputs via blackmagic. I plan to broadcast the final output via hdmi, to the 3rd Teradek for encoding a 10 mbps UDP stream to our local network. Any suggestions or recommendations?
Lzrd
#46 Posted : Monday, July 8, 2013 5:29:03 AM(UTC)
Lzrd
When saving delay clip and "quick play" it sometimes I lost main saund (embed to video signal SDI). Sound just turn off. What should I change that it wouldn't happen?
sdwinkelman
#47 Posted : Saturday, July 13, 2013 2:13:48 AM(UTC)
sdwinkelman
Generally, great program... nicely done!
I do have a few questions, and I apologize if they are answered somewhere else...
1) Is it possible to re-order the inputs? Currently, it seems the order they are added is what you are stuck with.
2) Can a list of music files be edited after the fact, or must you delete and re-create?
3) Is there some reason some mp3s in a list won't play? (they are simply skipped over)
Thanks!
#48 Posted : Saturday, July 13, 2013 8:39:23 AM(UTC)
1) Yes you can move the input by click and dragging the video area of the input on top of another input.
2) Lists are currently fixed at the time they are added
3) This is a known bug in windows with some mp3s. Try converting them to another format if possible, or if you are using 32bit vMix, try this filter:
http://dsp-worx.de/?n=9
sdwinkelman on 7/13/2013(UTC)
fenki86
#49 Posted : Thursday, July 25, 2013 4:54:31 AM(UTC)
fenki86
First up thanks for the great service! vMix is just working perfect for me.
We are live-streaming the handball-games of our club and therefore we are using a scoreboard.
I already managed to add a shortcut for adding goals via the settext-Option. However sometimes we need to stop the running clock too. I can easily do that via the Title Editor but I was wondering if there is a way to put the Play- and the Pause-Function on a shortcut too. Would be perfect to just hit a key and the time automatically pauses.
Thanks in advance for your help.
Greetz from Austria
Fenki
_______________________________________________________________
EDIT: Seems like I have just been overlooking it. The Function "StartCountdown" and "Pausecountdown" at the Shortcut-Settings probably just was to simple for me. Sorry for bothering.
Guest (5)
3 Pages<123
