Stinger Image Sequence - Trigger to add mp3 music track
Joined: 11/23/2016(UTC) Posts: 330  Location: USA Thanks: 179 times Was thanked: 26 time(s) in 25 post(s)
Hi Everyone,
I have an image sequence/stinger set up.
I want a music track to play while the trigger plays. It's a mp3 track that I have already set up as an audio input.
What kind of trigger do I need to add to the image sequence in order to start the music on "TransitionIn".
I've tried quickplay, and some others, but I'm not hearing any music.
Thanks!
Rowby
@ rowby
Simplest solution is to add the mp3 as a MultiView Overlay to the Image Sequence Stinger Input (sound for the Stinger), unless, of course, you want the mp3 to continue playing after the Stinger completes, in which case the Trigger would be "OnOverlayIn" "Play" "mp3 Input". (in either case, "Audio" button needs to be ON or Active for the mp3 audio Input)
Thanks, Ice,
For your quick solutions. Both will be helpful now and for my future needs.
Rowby
Joined: 7/23/2013(UTC) Posts: 136  Location: North Thanks: 14 times Was thanked: 13 time(s) in 11 post(s)
If I remember correctly, it is possible to add a .wav file with the same file name as the first image of the stinger animation. You can then avoid using multiview, inputs, or special triggers. edit: https://www.vmix.com/help20/?ImageSequence.html
 2 users thanked jip for this useful post.
