Joined: 1/3/2018(UTC) Posts: 4 Location: Oslo, Norway
Any Sdi or Hdmi duo or quad solution that support 2 or more different resolutions? F.ex 1920x1080 i50 and 1280x720 p50 at same production running 1920x1080 p50 internally?
Thank you Geir Otto
Thanks: 11 times Was thanked: 18 time(s) in 13 post(s)
the blackmagic support that each input have their own resolution
I would think that most dual/quad input capture cards would allow different signal formats on each input channel. I can vouch for the fact that the Magewell Pro Capture Dual/Quad HDMI & SDI cards work this way.
