gez737
#1 Posted : Tuesday, January 2, 2018 1:10:16 AM(UTC)
gez737
Can anyone please tell me what the numbers on the vMix main screen do and how to remove them?
See the attachment.
Any advice would be greatly appreciated.
Thanks in Advance,
Cheers
Gerry
File Attachment(s):
SportsNetUSA.net
#2 Posted : Tuesday, January 2, 2018 2:35:37 AM(UTC)
SportsNetUSA.net
What capture device are you using with vMix?
#3 Posted : Tuesday, January 2, 2018 2:57:31 PM(UTC)
I think it's coming from the settings of your graphic card.
There's one option to deactivate in the nVidia control panel.
It's been discussed before here, search a little in the forum.
streammediaevent
#4 Posted : Tuesday, January 2, 2018 4:08:43 PM(UTC)
streammediaevent
Turn off the FPS Counter in Nvidia GF Experience.
#5 Posted : Tuesday, January 2, 2018 4:27:28 PM(UTC)
Actually, it is recommended to disable/uninstall GeForce Experience all together as it impedes performance with vMix.
gez737
#6 Posted : Sunday, January 7, 2018 7:35:54 PM(UTC)
gez737
Thanks for you help.
The video card is Nvida 1060. The driver was updated and this got rid of the numbers on the screen.
Capture card is black magic Deck link, an old card - HD only.
Cheers
Gerry
