Joined: 9/29/2017(UTC) Posts: 16 Location: Surrey, BC
Thanks: 9 times Was thanked: 1 time(s) in 1 post(s)
Hello - I have been using the above Webcams as my capturing cameras. I have Windows 10. I am getting an error report "invalid pointer". I searched in the forums but it did not help.
Joined: 7/1/2015(UTC) Posts: 1,151   Location: Houston TX Thanks: 320 times Was thanked: 263 time(s) in 233 post(s)
I have no issue using those webcams on my vMix system. Are you using the Logitech supplied drivers & software? If so, you should uninstall it and use the generic UVC drivers instead. Logitech advised on how to do this here: http://support.logitech....oduct=a0qi00000069uigAAA
Joined: 2/14/2016(UTC) Posts: 118  Location: Oss Thanks: 12 times Was thanked: 15 time(s) in 14 post(s)
I also use a C920 webcam, never installed one of the Logitech-drivers, just plugged it in...
mjgraves wrote:I have no issue using those webcams on my vMix system. Are you using the Logitech supplied drivers & software? If so, you should uninstall it and use the generic UVC drivers instead. Logitech advised on how to do this here: http://support.logitech....oduct=a0qi00000069uigAAA Thank you! I will give that a try. Merry Christmas!
Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
stampersplus wrote:mjgraves wrote:I have no issue using those webcams on my vMix system. Are you using the Logitech supplied drivers & software? If so, you should uninstall it and use the generic UVC drivers instead. Logitech advised on how to do this here: http://support.logitech....oduct=a0qi00000069uigAAA Thank you! I will give that a try. Merry Christmas! well.... did it work????? Thanks
