2 Pages<12
s0wndman
#21 Posted : Tuesday, December 19, 2017 9:45:07 AM(UTC)
s0wndman
bentzmi,
It sounds like your problem may be different than mine since I did not have trouble with my outputs. As far as my inputs went, I actually found that the solution was to change the Video Format in the Input settings from Default to RGB32.
s0wndman attached the following image(s):
bentzmi
#22 Posted : Thursday, December 28, 2017 10:44:04 PM(UTC)
bentzmi
Ya, the outputs were a different issue (you can't have external renderer checked and then select "none" for the device to disable it. You have to disable the external renderer too).
And your solution for the inputs worked for me too....everything blackmagic related needs to be hardcoded. I guess this is the cost of using cheaper gear.
2 Pages<12
