mtregael
#1 Posted : Friday, December 15, 2017 5:52:02 AM(UTC)
mtregael
Hi all,
First Problem:
I am trying vMix and i need to use "vMix Social" a lot for facebook live.
The problem i have is when i use the "Trigger overlay" of vMix Social:
There is a small delay, but visible on output, before the title field update when the overlay is activated.
So, the first milliseconds, we can see the previous title and its live change. The rendering is awful as it seems to flicker.
I need that feature to work properly because social networks are run independently by an operator on its own computer.
Second question:
Also, another question, is about triggers for that overlay:
I'd like the "automatic" overlay to be disabled after some delay.
I have tried to use a "OverlayIn" trigger but it does not work as i want. I explain:
If there is only one comment to display, it work fine. The overlay is activated by the "Trigger overlay" of vMix Social (with the bad flicker effect of course) and it is deactivated after the delay specified in the trigger.
The problem is if the Social Operator send another comment during the "off delay" of the overlay trigger, it does'not reset the "off delay" of the trigger and the overlay is deactivated at the initial delay ending.
It's not very easy to explain...
Example:
- The OverlayIn trigger delay parameter is 10 seconds to do an overlay off.
- The first comment is sent by "Trigger overlay" de vMix social.
- A second comment is sent 7 seconds after...
- the overlay is deactived 3 seconds after that second comment because the trigger delay is 10 seconds (the 7 second of the first comment and 3 seconds of the second one).
We should be able to reset the trigger delay when a new comment is sent.
Is there a way to do that ?
