Joined: 7/8/2016(UTC) Posts: 53   Location: Ukraine Thanks: 13 times Was thanked: 5 time(s) in 3 post(s)
You will need to use the TV Feed adapter from Genius Sports. Then pay for the TV feed to be enabled on the Fiba Live Stats software which currently v7 and only just released the updated version of the adapter. If your lucky like myself you will have the license already installed from either the league or association. The TV feed is not cheap per game or season. You need to write your own code to format the xml into usable date that be used in Vmix. Fiba Live Stats feed - ASNTV demoGame demo - Live tv data feed. Some of the data like player images and graphics backgrounds are from CMS Stats pc's need to be on the same network as your production. Recommended to split the web feed and tv feed on separate networks. eg one laptop for tv feed and one for webstats. Regards James
 1 user thanked corporatejames for this useful post.
corporatejames wrote:You will need to use the TV Feed adapter from Genius Sports. Then pay for the TV feed to be enabled on the Fiba Live Stats software which currently v7 and only just released the updated version of the adapter. If your lucky like myself you will have the license already installed from either the league or association. The TV feed is not cheap per game or season. You need to write your own code to format the xml into usable date that be used in Vmix. Fiba Live Stats feed - ASNTV demoGame demo - Live tv data feed. Some of the data like player images and graphics backgrounds are from CMS Stats pc's need to be on the same network as your production. Recommended to split the web feed and tv feed on separate networks. eg one laptop for tv feed and one for webstats. Regards James Thx for reply. It's not easy. OK, will see what can we do with this, thx once more
tkachuk.alex wrote:corporatejames wrote:You will need to use the TV Feed adapter from Genius Sports. Then pay for the TV feed to be enabled on the Fiba Live Stats software which currently v7 and only just released the updated version of the adapter. If your lucky like myself you will have the license already installed from either the league or association. The TV feed is not cheap per game or season. You need to write your own code to format the xml into usable date that be used in Vmix. Fiba Live Stats feed - ASNTV GFX demoGame demo - Live tv data feed. Some of the data like player images and graphics backgrounds are from CMS Stats pc's need to be on the same network as your production. Recommended to split the web feed and tv feed on separate networks. eg one laptop for tv feed and one for webstats. Regards James Thx for reply. It's not easy. OK, will see what can we do with this, thx once more Sorry had the wrong link for the demo. I have updated it now. Fiba Live Stats feed - ASNTV GFX demo
OK. I Find many of them< and TV Feed and docs about.. Let's work )) Thx
Joined: 1/23/2018(UTC) Posts: 16  Location: Poland Thanks: 6 times Was thanked: 2 time(s) in 2 post(s)
