Does anyone have suggestions for a bang-for-buck monitor to use with vMix? Just 1080p is fine and it doesn't have to be color accurate or anything. Just a display for the GUI (i'll probably pick up two). The best one for the price, budget segment.
I read that it's best to match the refreshrate of the monitor to the master framerate of your preset. So 25hz for 25p presets or can it also be 50 or 75hz?
Thanks: 26 times Was thanked: 34 time(s) in 30 post(s)
I can't remember all the things I factored in as it was last year but I spent ages deciding as I had to buy three and went for this model
LG 29" 29UM68-P IPS Full HD FreeSync UltraWide HDMI Gaming Monitor
