Joined: 1/30/2017(UTC) Posts: 9  Location: Tennesse, USA Thanks: 10 times Was thanked: 5 time(s) in 3 post(s)
Let's make a list of all vst plugins that have been tested in vmix. Include what it does and a link to download.
Admin: Hope this is okay. If not please make an official list.
I think this "list" should be in the "3rd-party softwares" section of the forum
 1 user thanked kjones9999 for this useful post.
 3 users thanked DWAM for this useful post.
 1 user thanked mackenlyj for this useful post.
You have been a member since:: 4/4/2016(UTC) Posts: 236  Location: Not Los Angeles CA Thanks: 86 times Was thanked: 28 time(s) in 23 post(s)
Exactly what I was going to recommend and I just did a 5 Live Show where I discuss how I use this. I put this on the MASTER and it shows me exactly what I am sending out. Also once I added this plug in it showed me a nasty 8k and 16k tone that I have and helped me diagnose how to fix it. I got lucky on the fix and now I know how to avoid it. Thanks to vMix for adding VST's as I probably never would have found this otherwise. Here is a link to my 5 Live Show where I discuss this plug in The 720P stream does not show the 8k/16k tone on screen, d'oh!!!
 3 users thanked RichShumaker for this useful post.
Thanks: 106 times Was thanked: 2 time(s) in 2 post(s)
Just bought bluecat patchwork. It works very well and can load vst2 plugins too. Testing now with the free vst 2 reaplugs (reaper) inside patchwork. One is very interesting: ReaFIR can remove background noises live. There is also midi support inside patchwork, that's next to test.
Joined: 12/20/2016(UTC) Posts: 191   Location: Milano Was thanked: 21 time(s) in 13 post(s)
Hi Guillaume. I saw some plugins in the page you indicated, I downloaded the chorus but there is just one file with .dll extension. It's a library and I don't know in wich folder I have to put it.
Quote:Hi Guillaume. I saw some plugins in the page you indicated, I downloaded the chorus but there is just one file with .dll extension. It's a library and I don't know in wich folder I have to put it. Ciao Lino! make sure the plugin you downloaded is 64 Bits and VST3. as the case may be, just copy and paste this dll in folder : Code:C:\Program Files\Common Files\VST3
Guillaume
DWAM wrote:Quote:Hi Guillaume. I saw some plugins in the page you indicated, I downloaded the chorus but there is just one file with .dll extension. It's a library and I don't know in wich folder I have to put it. Ciao Lino! make sure the plugin you downloaded is 64 Bits and VST3. as the case may be, just copy and paste this dll in folder : Code:C:\Program Files\Common Files\VST3
Guillaume I did it but it still doesn't work. I downloaded HY-ChoFla 64 bit, I hadn't any folder named VST3 in the path you indicated so I created it, I put the file HY-ChoFla_64.dll in that folder but it doesn'work. I installed the plugins from voxengo and they work perfect. Maybe I'm missing something. I'll try again. Thank you in any case. Lino
Thanks: 25 times Was thanked: 8 time(s) in 7 post(s)
I think the plugin needs a vst3 extension, otherwise vMix doesn't see it.
Quote:I think the plugin needs a vst3 extension, otherwise vMix doesn't see it. Yep! @Lino: you certainly downloaded older VST plugins which are not VST3 64 Bits. Check this link for a free VST3 chorus plugin: https://www.bluecataudio...Products/Product_Chorus/Guillaume
I tried several Waves plugins in the last couple of days. Pretty impressive! - MaxxVolume was referred to before by the vMix team. It's not my favorite but it is very efficient in many situations. - NS1 is a noise suppressor to be used on inputs to wipe out background noise. It is absolutely transparent and doesn't alter the sound at all, just removes the background noise. I love this one! - L1 Ultramaximizer is a compressor and limiter that works great on the Master bus for final "masterization". Really great! These are not free but can be tried for 7 days. There are huge discounts at the moment! Won't last long I think. This link below offers a 10%-off coupon on all orders of VST3 plugins at waves.com. https://www.waves.com/r/fgcn5qGuillaume
DWAM wrote:Quote:I think the plugin needs a vst3 extension, otherwise vMix doesn't see it. Yep! @Lino: you certainly downloaded older VST plugins which are not VST3 64 Bits. Check this link for a free VST3 chorus plugin: https://www.bluecataudio...Products/Product_Chorus/Guillaume Ok Guillaume, this works. Thank you.
Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
Only 15 hours left to get up to 75% discount on waves plugins. If you want to benefit this offer, don't wait ! This coupon link gives you extra 10% on all orders : https://www.waves.com/r/fgcn5q
