iamralphsutton
#1 Posted : Friday, December 1, 2017 6:58:26 PM(UTC)
iamralphsutton
Is this possible?
NHT
#2 Posted : Friday, December 1, 2017 7:16:37 PM(UTC)
NHT
What as, images, titles, png sequence?
iamralphsutton
#3 Posted : Friday, December 1, 2017 8:58:53 PM(UTC)
iamralphsutton
I have about 10 lower third images. From xsplit - I want to import all at once. each as a sep input -
along with a few smaller images for bugs, etc.
I'd like to just add them all at once.. they are all JPGS or PNGs.
JimJacobs
#4 Posted : Saturday, December 2, 2017 1:39:06 AM(UTC)
JimJacobs
It's easy....open your vMix session. Select the tab under which you want all the graphics to appear. Now open a file explorer window and navigate to the graphics you want to bring in vMix. Highlight them, then just drag the directly into vMix. They will appear as individual inputs. For instance if you have 10 new files you will get 10 new inputs. Depending on how you have the graphic sized you may have to do some manipulation from with in the mix to make them appear on your screen the way you want them to look in your production. Anytime I'm going to use a static graphic in vmix I will size it prior to importing it so that I know what look I'm going to have once I use it as an overlay in vmix.
thanks 1 user thanked JimJacobs for this useful post.
iamralphsutton on 12/2/2017(UTC)
