Title / Xaml and Datasource
Hello i'm wondering if I can set only text in a csv as a datasource for Ttile/XAML
-0,88 is shown as -0,88 (it's OK) 1,12 is shon as 112 (should be 1,12) 1,10 is shon as 110 (should be 1,10) 1.10 is shown as 1,1 (should be 1.10)
how can I manage, that "," is "," and "." is "." (comma is comma and dot is dot) in Numbers?
in the CSV I have "-0,88","1,12","1,10","1.10" also öäüÖÄÜé and so on are wrong after import of a csv datasource
Numbers should be in the tilte as they are in the csv
any suggetions?
Joined: 12/27/2012(UTC) Posts: 5,535  Location: Belgium Thanks: 319 times Was thanked: 1021 time(s) in 838 post(s)
Quote:also öäüÖÄÜé and so on are wrong after import of a csv datasource file has to be saved with UTF-8 encoding Quote:in the CSV I have "-0,88","1,12","1,10","1.10" i don't think you are allowed the quotes Quote:1.10 is shown as 1,1 (should be 1.10) is related to your language settings
Hi
the very first time, I imported the datasource, it works with the äöü and so on
the I saved the CSV (original generated with notepad) with Excel and the umlauts are wrong
from this moment, I can save they as I want, no success
quotes are not the problem same issue with and without quotes and I need the quotes because the seperator "," is also in the text
language setting is set to german and it's not possible to change beause other programs will only work with this settings.
Is there any chance to import numbers as text (like excel does it)?
New Question
I have one title for names. If the name (with space inside) is longer then the field, I get two lines is there any way, to truncate the name (like it is done if there is no space in the source)
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
I don’t do much with Datasources in vMix. But Notepad has a history of breaking other document lists by adding its own formatting. Notepad++ is a great editor that will respect your original formatting.
