iamralphsutton
#1 Posted : Thursday, November 30, 2017 10:43:25 AM(UTC)
iamralphsutton
Is there a way to save the highlights you created in Instant Replay as separate files?
avsoundguy
#2 Posted : Friday, December 1, 2017 2:24:37 PM(UTC)
avsoundguy
I am running into the same issue, previously there were separate files for each replay and in the last couple of version I have realized that is no longer the case. I get 2 files, one with video and a blank screen video, which I suppose is for audio??
Has me and my customers confused.
Cpilcher
#3 Posted : Friday, December 1, 2017 3:02:11 PM(UTC)
Cpilcher
I know you can export the selected reply clips to a file. And as I can remember my replay clips that are natively saved to disk are a single file with audio... but I’m not near my PC to confirm this.
thanks 1 user thanked Cpilcher for this useful post.
avsoundguy on 12/1/2017(UTC)
avsoundguy
#4 Posted : Friday, December 1, 2017 3:06:04 PM(UTC)
avsoundguy
OK I figured out how it works now, when done using IR for your event, you can chose "Export Clips" in the replay control panel (far right) to save any or all the replay clips from your event. The files are saved in a folder called "Export" within your replay folder.
thanks 1 user thanked avsoundguy for this useful post.
ali666 on 9/20/2024(UTC)
Cpilcher
#5 Posted : Friday, December 1, 2017 3:09:03 PM(UTC)
Cpilcher
Well Done. You can do that real-time as well, I push the clips to a Drop Box folder that our social media guy uses for Facebook and Twitter.
