vMix Outputs (ovelays recording)
Dears! I have one question when it come to the outputs configuration. I'd like to configure my streaming setup as follows: 1-Streaming the final output with all the overlays. 2-Recording the final output but without some overlays. 3-External output the final output with all the overlays. I tried to configure it in the outputs menu but it seems that it whe I remove some overlays on the recording output it does as well on the stream out. As the image reclects: https://ibb.co/fhdhq6Could somebody please give me a hand?
Does somebody know how to do it?
@ nilgarcia0
Which edition of vMix do you have? Streaming, Recording and External 1 always share the same Output. vMix 4K and vMix Pro will allow you to record a second Output with or without overlays.
Hi ICeStream,
I have the HD version but I can upgrade if necessary. I now installed the trial versio to try it but I don't know how to do it.
