benmower
#1 Posted : Sunday, November 19, 2017 8:34:09 AM(UTC)
benmower
I am new to using the software and just have a quick question im hoping somebody can help me with.
While using the software I want to be able to play an audio track but play separate videos over the track at the same time, Mainly visual stuff. Is it possible to mix audio with video with the software or can I only play audio on its own.
Thank you - Ben
SportsNetUSA.net
#2 Posted : Monday, November 20, 2017 4:37:20 PM(UTC)
SportsNetUSA.net
Yes you can do that. Play the audio track by activating it as an Overlay. Or you could play the the video clips as overlays.
elvis55
#3 Posted : Monday, November 20, 2017 6:18:00 PM(UTC)
elvis55
Switzerland
Multi View.
Transitions Fade
Gruss
zenvideo
#4 Posted : Tuesday, November 21, 2017 6:20:53 AM(UTC)
zenvideo
If you mean, "Can you hear a single audio track whilst seeing (and switching between) a number of videos?", the answer is "Yes". You can have a number of files (audio or video) as different inputs and all can play simultaneously, with the audio from each being mixed together in the Audio Mixer panel, and at the same time you can switch inputs to the Program output to determine what video is seen at any time.
