66 Pages«<2021222324>»
mburel1980
#421 Posted : Wednesday, November 15, 2017 3:39:25 PM(UTC)
mburel1980
Was thanked: 14 time(s) in 12 post(s)
Ok, tested and approved !!
Thank you Elgarf, you´re the best :D
Cheers,
sportbase
#422 Posted : Thursday, November 16, 2017 12:59:56 PM(UTC)
sportbase
thank you for that software! From our tests it is really doing its job and we are going to use it in our sport broadcasting.
I would have one small feature request :)
As we are used to vmix - for example when we start the timer, we just start it and close the window, so when we do the same with UTC, guess what is happening? we are closing it.
It needs some dialog box
"Are you sure you want to close UTC" YES | NO
it would make it a bit more safe, as in our first production test, we have closed it and stadium timer stopped working ;)
elgarf
#423 Posted : Friday, November 17, 2017 1:18:29 AM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
Ok, it looks useful =)
I've added this and also in "lock" mode close button is invisible 🐱‍👤
JAIRODJ
#424 Posted : Saturday, November 18, 2017 10:12:26 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
On my PC, sometimes UTC collapses and at intervals it still appears that it does not respond.
Please, if you tell me how to get the UTC LOG, to send them and they can help me ... know if the error is my PC or what happens.
I have never done this to get the LOG of any program.
Regards
Note. I am using the current version of UTC 16-11-2017
elgarf
#425 Posted : Saturday, November 18, 2017 10:40:19 AM(UTC)
elgarf
Russian Federation
@JAIRODJ, tick "enable log" check box on bottom of UTC. Then you can find log in your documents/vMixUTC/logs folder.
Btw, that's a bit strange. Can you share also vmc&preset files?
corporatejames
#426 Posted : Sunday, November 19, 2017 1:57:37 AM(UTC)
corporatejames
Can you put back the min and maximise buttons? Like the close button hidden but sometimes like to
minimise the window, I know I can just unlock first but just adds a extra step when you don't have much time.
elgarf
#427 Posted : Monday, November 27, 2017 2:23:10 AM(UTC)
elgarf
Russian Federation
@corporatejames, now close button just disabes, you can use maximize/minimize buttons =) please re-download UTC.
thanks 1 user thanked elgarf for this useful post.
corporatejames on 11/30/2017(UTC)
corporatejames
#428 Posted : Thursday, November 30, 2017 1:57:53 AM(UTC)
corporatejames
Great thanks @elgarf Still having UTC crash using your updated NDI Monitor dll. Have no issues with old version.
elgarf
#429 Posted : Saturday, January 6, 2018 6:48:27 AM(UTC)
elgarf
Russian Federation
Hey. I know you want this =) multiselect widgets.
First post
I made gif, so click on image to view it. Also you can select one or more widgets by pressing Ctrl. It works on unlocked widgets.
@corporatejames, still can't catch where new NDI crashes. Can you send me log or screenshot of error?
I also think about making UTC for web browser, but there is so much work =(. So I would stay on win version)
elgarf attached the following image(s):
thanks 2 users thanked elgarf for this useful post.
mburel1980 on 1/7/2018(UTC), corporatejames on 1/10/2018(UTC)
veemix
#430 Posted : Friday, January 12, 2018 2:31:12 PM(UTC)
veemix
First, @elgarf, thanks for this useful bit of kit.
I am running into an issue with buttons, however. Installed this version (https://dl.dropbox.com/s/lcz9dr62o7fraix/vMixUTC_Donateware_GUID_Conditions.zip). When I create a button I do not see any commands in the drop-down menu. Am I missing something?
Thanks so much for any help you all can provide.
veemix attached the following image(s):
elgarf
#431 Posted : Friday, January 12, 2018 2:43:05 PM(UTC)
elgarf
Russian Federation
@veemix, looks like something wrong with your Functions.xml file =( tick "Enable Log" checkbox, restart UTC and send me log file, please.
veemix
#432 Posted : Friday, January 12, 2018 3:20:38 PM(UTC)
veemix
@elgarf, thanks.
I figured it out. I had the functions.xml file saved next to the .exe in my Program Files. I moved the folder to my Documents folder and it's working now. Thank you!
elgarf
#433 Posted : Saturday, January 13, 2018 1:26:01 AM(UTC)
elgarf
Russian Federation
@veemix, glad it worked for you. Btw, placing UTC into program files folder is not good idea) it read/write files next to exe file, so it probably need admin rights.
Brutuss
#434 Posted : Wednesday, January 24, 2018 8:03:18 AM(UTC)
Brutuss
Where i found Weatherapp.xaml on folder ?
desmar
#435 Posted : Wednesday, January 24, 2018 2:45:59 PM(UTC)
desmar
Canada
@elgarf,
Could you please add version number either in title bar or in an about box.
So we know we have the most recent version of the app.
Keep up the good work.
elgarf
#436 Posted : Wednesday, January 24, 2018 11:36:06 PM(UTC)
elgarf
Russian Federation
@Brutuss, I'll look where it can be, but there is chance, that it lost. Btw, weatherapp somewhere from another thread.
@desmar, I'll add last update/compile date into title.
liwarnyamannya on 1/26/2018(UTC)
chezter
#437 Posted : Friday, January 26, 2018 7:27:05 PM(UTC)
chezter
I have a problem, it happens when I'm using UTC, normally, line _up, statistics, titles, NDI monitor and command buttons.
At first it works normally, after a time of 15 minutes, the application closes automatically.
The problem always occurs, ce closes the UTC without more.
Psd: Use w10, i7 770k - 32 gb ram, Nvidia Gtx 1080 -SSD 1 TB.
I use them with xaml files.
elgarf
#438 Posted : Friday, January 26, 2018 11:04:23 PM(UTC)
elgarf
Russian Federation
@chezter, can you show me log file?
chezter
#439 Posted : Saturday, January 27, 2018 11:44:08 AM(UTC)
chezter
Here it is, it closed without further ado.
https://drive.google.com...YRNzKdPL1C4C1LZoOmA/view
elgarf
#440 Posted : Saturday, January 27, 2018 12:47:42 PM(UTC)
elgarf
Russian Federation
@chezter, hmmm... I don't see nothing bad. You also can look into windows event log, there should be event connected with UTC, maybe it show error more clear.
Guest (18)
