Severe Aliasing on Input Previews
Joined: 8/5/2017(UTC) Posts: 583  Location: Manitoba Thanks: 121 times Was thanked: 323 time(s) in 184 post(s)
The Input Previews appear to have an aliasing issue when processing diagonal lines. (see attached screen shot on Cam1 and Cam3) Computer : ASUS Rog Laptop, i7 CPU, 32Gig RAM, 512 GB M2 Drive, 1TB SSD for Replays, NVidia 980M Video Card vMix version: 20.0.0.30 Cameras set to : 1080i59.94 vMix Master Frame rate: 59.94i Output Size : 1920 x 1080 I have tried a multitude of different settings (Master Frame Rate, De-interlacing inputs, etc) but no difference. Perhaps this is just inherent of the processing in a software based switcher. I'm used to hardware switchers.. thanks for any suggestions, Richard raugert attached the following image(s):  Screenshot 2017-11-06 18.30.58.png (1,883kb) downloaded 18 time(s).You cannot view/download attachments. Try to login or register.
The input previews are a lower resolution image compared to the program and preview windows. I think that is all you are seeing. The program window looks fine.
You're right, it's more of a resolution than aliasing phenomenon. I'm assuming that this is done deliberately to maintain vMix performance somewhat at the expense of the Multiview quality. I could see where rendering the Input Previews in higher resolution would take more horsepower. I'll get used to it..
