Murchik
#1 Posted : Wednesday, November 8, 2017 10:00:43 AM(UTC)
Murchik
Ukraine
who prompts, on intel intel X9 vMix (10 cores) is very incorrectly works - it slows down, hangs and loads the processor very much. Render time below 40 ms is not lowered. (Nvidia 1080ti)
sinc747
#2 Posted : Wednesday, November 8, 2017 2:12:13 PM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Need more info on your setup and your workflow.
- Tom
richardgatarski
#3 Posted : Wednesday, November 8, 2017 6:43:50 PM(UTC)
richardgatarski
Murchik, Have you searched the Forum?
You can find this important topic on X99
RandomStreamer
#4 Posted : Thursday, November 9, 2017 4:52:51 PM(UTC)
RandomStreamer
im using x299 with 7900x with 150% performance increase over 7700k.
please give us more details about your hardwaree.
best,
RS
Murchik
#5 Posted : Friday, November 10, 2017 6:34:50 PM(UTC)
Murchik
Ukraine
Guys, the situation is funny and sad at the same time! Post 2 days struggled with the situation and already wanted to return the components back to the seller. All tests the system was successful (CPU-Z, GPU-Z and much more), but the solution to the problem was that the graphics card was not detected by some graphics applications at all (although in Windows and vMix and BIOS), there were no errors.
Result!
https://www.asus.com/ua/...oards/PRIME-X299-DELUXE/
made a too weak latch for PCIe 3.0 x16 where the NVIDIA 1080 TI graphics card was installed and when it was used, it apparently partially departed partially.
I was helped in this case by usual cheap plastic ties for 2 dollars packing.
Now everything works great.
Murchik attached the following image(s):
Murchik
#6 Posted : Friday, November 10, 2017 7:47:00 PM(UTC)
Murchik
Ukraine
My last build of the system!
PRIME X299-DELUXE
Intel® Core™ i9-7900X X-series Processor
ROG-STRIX-GTX1080TI-O11G-GAMING
G.SKILL TridentZ RGB Series 128GB (8 x 16GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Intel X299 Platform Desktop Memory Model F4-3600C17Q2-128GTZR
blackmagic DeckLink Duo 2 - х 3
win 10 pro
vMix 20 pro
Edius 7,53 pro
Adobe After Effects CC 2017
Western Digital Black 6TB 7200rpm 128MB WD6001FZWX 3.5 SATA III(WD6001FZWX) х 4 (Raid 10)
Western Digital Black 6TB 7200rpm 128MB WD6001FZWX 3.5 SATA III(WD6001FZWX) х 1
Western Digital Black SSD 256GB M.2 2280 PCI Express 3.0 TLC (WDS256G1X0C) (System)
Kingston SSDNow KC400 256GB 2.5" SATAIII MLC (SKC400S37/256G) (support video for projekts)
Very successful modification turned out ...
RandomStreamer
#7 Posted : Saturday, November 11, 2017 2:16:06 PM(UTC)
RandomStreamer
I've had similar issues with GPU before, and ended up returning to the seller.. You should do the same.
Using plastic ties to solve your issue shouldnt be the way to go.
Best,
RS
RobLambert
#8 Posted : Thursday, November 16, 2017 7:26:09 PM(UTC)
RobLambert
Murchik,
Very interesting and I am happy for you.
What an amazing system. Will you please tell me what benefit in vMix comes from so much memory. Everything you did was thoughtful; and, I sure would like to know the rational for your RAM decision.
Thank you very much.
Rob
NiBTour
#9 Posted : Saturday, November 18, 2017 11:31:10 AM(UTC)
NiBTour
RobLambert wrote:
Murchik,
Rob
My guess would be not so much for vMix but for after effects running on the same system. probably for a eSport setup i do the same although i haven't moved to the x299 just yet.
thanks 1 user thanked NiBTour for this useful post.
RobLambert on 11/18/2017(UTC)
RandomStreamer
#10 Posted : Saturday, November 18, 2017 3:51:01 PM(UTC)
RandomStreamer
NiBTour wrote:
RobLambert wrote:
Murchik,
Rob
The only VMIX use for high amounts of ram is to add DELAY on inputs. I remember using 16GB once to delay a couple of minutes in a input.
I use 32GB on my setups, but rarely use more than 16.
best,
RS
thanks 1 user thanked RandomStreamer for this useful post.
RobLambert
#11 Posted : Saturday, November 18, 2017 4:05:01 PM(UTC)
RobLambert
You ALL just keep saving me money....or at least keeping me from wasting it.
Rob
Murchik
#12 Posted : Wednesday, November 22, 2017 3:14:48 PM(UTC)
Murchik
Ukraine
You have not read it to the end, the system is collected not only for vMix but also for other works related to video production. Moreover, with such an amount of RAM it makes sense to completely disable the Windows paging file (manually, by hand, since no matter how much memory Windows still uses, the paging file is used). Then you get a significant increase in performance (without a swap file), and the average memory size for the regular work is 17-55 gigabytes. With more serious work and a complex rendering, you will actually begin to understand that there is not enough memory!
RandomStreamer
#13 Posted : Thursday, November 23, 2017 1:27:15 PM(UTC)
RandomStreamer
Very well thought, considering your PC isn't vmix only :)
