Joined: 7/14/2017(UTC) Posts: 100   Location: South Florida Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
Just tried 2 ipads in an attempt to connect using vmix. The remote user just sees their own video and nothing else. I see that the call is connected via the call manager, but that's it. No video or audio from remote. Is this ios compatibility for real, or am I doing something wrong?
Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4793 time(s) in 1645 post(s)
Can you confirm the latest vMix 20 is installed?
The two requirements are iOS11 using Safari and vMix 20 or higher. (will not work with vMix 19)
We have tested on an iPhone 7 and an iPad Mini.
I have met the parameters you have, and I still don't get return audio to host from caller. Also, the program freezes both my ipads, and my droid phone. Works fine from a PC.
Just ran a test using the latest iPhone 11 release (11.1.1) and could connect to vMix Call with both audio and video working in both directions. Note that when adding a vMix Call input to vMix, if it isn't live it will be muted by default, so you will need to click the Audio button underneath it so that it is green to hear the callers audio.
Martin vMix
