Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
I was playing around today with using VLC to run a loop of video over the network to test performance and reach. Turns out that VLC was lagging horribly. vMix? - runs beautifully of course! jittery video suddenly played like butter.
lael wrote:I was playing around today with using VLC to run a loop of video over the network to test performance and reach. Turns out that VLC was lagging horribly. vMix? - runs beautifully of course! jittery video suddenly played like butter. Not much to work off here. Need to know a bit more about the media file specs (like codec, frame size, frame rate), network setup and performance of the VLC system. Also, is the VLC system 32 or 64-bit? NDI performance is better when everything is 64-bit. I use VLC Player with the NDI plug-in all of the time (usually running multiple instants of VLC) and it works great. Kane Peterson NewTek
About VLC and NDI
(NDI)
by spino
5/14/2017 10:19:27 AM(UTC)
