RichShumaker
#1 Posted : Thursday, November 2, 2017 6:18:29 PM(UTC)
RichShumaker
Was thanked: 28 time(s) in 23 post(s)
I discuss this Feature Request in my most recent 5 Live video
?t=54s
I want to be able to change the aspect ratio using the X and Y zoom then 'lock' them.
That would give you the ability from then on to zoom using the whole zoom and would not require complex math to get things to fill in properly.
Thanks everyone for checking this out.
Rich Shumaker
RichShumaker
#2 Posted : Friday, November 3, 2017 10:50:59 PM(UTC)
RichShumaker
Solution Found
Thanks Martin for your help.
I will post a video soon.
Here is the wordy description hopefully you can follow it until the video is up.
You make your adjustments to get the image "square" or proper.
Then create a blank input and use the multiview to put that input into it.
Now you can use the Zoom Tool and it will work.
Thanks again Martin.
Rich Shumaker
