clafarge
#1 Posted : Saturday, October 21, 2017 11:32:35 AM(UTC)
clafarge
Was thanked: 20 time(s) in 13 post(s)
I just hooked up my new NewTek NDI PTZ1 and discovered that, when adding the NDI input, the PTZ settings require that you a) select the Device Type and b) enter the IP address. I'm not sure what can be done about a), as I don't live in that world and I have no idea what metadata is sent from the device, but in the case of b), as the camera was selected as a network resource, we should already have the IP address of the camera device. It would be helpful to auto-populate the IP address in a metadata value on the input for use in the IP Address field (or Web Address field, as appropriate for other devices).
Thank you!
Chad
