PreviewInput Triggers not working correctly
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
Hi guys,
in our project with 100+ inputs (liveinputs, graphics, clips, audio, titles, ...) we use a lot of triggers to automate processes. For a couple of weeks now we also use the PreviewInput shortcut as triggers, so that vmix puts the item in preview which is next according to our plan and make things easier for our director. But these Triggers keep working incorrectly, as they put a different item to preview as we chose from the dropdown menu. When we - for example - set up the following trigger for Graphic1 (e.g. Input 110) OnTransitionIn, PreviewInput, Delay 1000ms, Graphic2 it works well for this time we use the project. At the end of the day we save the project and from the next time on we load the project it isn't Graphic2 which goes to Preview anymore but another file (withn 3 inputs left or right to the correct one) although the trigger is setted up correctly when we double check it.
That keeps happening for almost every PreviewInput Trigger we did set up in the last couple of weeks. We changed our plans and found a working workaround but I still think it is very strange or even wrong behaviour. Maybe we added or closed inputs near or even in between Graphic1 and Graphic2 bevor saving the project but as the triggers are not related to input numbers this shouldn't affect the triggers at all, should it?
Any idea?
Cheers, Daniel
