STADIORADIO
#1 Posted : Thursday, October 19, 2017 9:03:01 AM(UTC)
STADIORADIO
see video please
#2 Posted : Thursday, October 19, 2017 10:46:07 AM(UTC)
@ STADIORADIO
If you are saving the "Video Delay" as a clip to play later, then there is no need to set-up the Trigger within the Video Delay Input (as you are never cutting to that "Live" and thus Triggering the desired action).
If you "Save" the clips to a "List", then you can set-up Triggers within that List (after the first clip is saved) and the Trigger will engage any time you go to that List Input "Live" (you will need to manage the "List" for proper clip to playback).
If you save each clip as it's own Input, you will have to manually insert Triggers to each as they are essentially NEW Inputs each time, as there is no way to automatically "Add Input" with predetermined Triggers (aside from making Virtual copies of an Input).
Be aware that if your "Video Delay" Input is of your Output, then you are recording your overlays already and it cannot be removed.
STADIORADIO on 10/19/2017(UTC)
