NDI
NDI over vpn
I found that the NDI signal(generated by NDI spark,or NDI cam,or NDI CONNECT) cannot work over VPN however, the NDI signal generated by VMIX can work over vpn
but, the bitrate is so high (50-70mbps) so that it can not be used on internet
Thanks: 15 times Was thanked: 1 time(s) in 1 post(s)
bh1054010 wrote:I found that the NDI signal(generated by NDI spark,or NDI cam,or NDI CONNECT) cannot work over VPN however, the NDI signal generated by VMIX can work over vpn
Try www.ndi.cloud
NDI
NDI over vpn
