Hi! I use canon AHX1 with firewire ad it has for resolution 1440*1080i. In vmix there isn't this resolution when I do add camera. There is a solution?
Joined: 5/13/2014(UTC) Posts: 519   Location: Manchester, UK Thanks: 2 times Was thanked: 183 time(s) in 130 post(s)
I don't know for sure because I don't have one of these cameras, but what I can tell you is that the camera is shooting 1920x1080, with the 1440x1080 being an anamorphically "squashed" version, so 1920x1080 is the square-pixel size that you should select in vMix, and hopefully you can get the anamorphic picture stretched horizontally to fill the screen, after which it will look "normal" again. HDV worked like this as a form of image compression to help reduce the data rate to be recorded onto HDV tape.
Joined: 12/19/2013(UTC) Posts: 600   Location: Belgium Thanks: 75 times Was thanked: 91 time(s) in 75 post(s)
XHA1 is HDV, those are not square pixels. We used 4 of them for a long time via component, those are excellent cams. We mixed them with normal HD cams and didn't see the diffference.
