2:1 Aspect Ratio - 360vr 2048 x 1024
Anyone know how to create a custom aspect ratio/pixel size of 2048 x 1024 for 360vr streaming? I can easily create a custom canvas in Wirecast but cant seem to find a solution in vMix. Thanks in advance. TheStreamingGuys attached the following image(s):  Screen Shot 2017-10-11 at 1.54.56 pm.png (198kb) downloaded 1 time(s).You cannot view/download attachments. Try to login or register.
Joined: 1/13/2010(UTC) Posts: 5,325  Location: Gold Coast, Australia Was thanked: 4728 time(s) in 1620 post(s)
For live 360, most CDNs actually recommend standard 16:9 resolutions, such as YouTube: https://support.google.c...ube/answer/6396222?hl=enThis means stretching whatever size the source is coming in to the full HD frame and then on the other end YouTube will convert this back to 360. Regards, Martin vMix
Hi Martin, We are streaming from Flemington with 4 x ZCam at 2048 x 1024 into Wowza, pulling the RTSP from Wowza of each rasp stream into Wirecast at 2048 x 1024, switching the selection and streaming to Facebook at 2048 x 1024. It works perfectly in that workflow and I didn't really want to 'stretch' and trick the system. Ill give it a try and let you know the results.
