Systems
Looking for any input before building this system
I think it's better to have several hard disks - a small SSD for system only (120 or 240 GB) - another one for projects data (SSD or not 240/500 GB) - a large SSD for recordings 500/1000 GB
Guillaume
Joined: 10/25/2012(UTC) Posts: 182 Location: Barbados
I totally concur with Guillaume
Maximus
Thanks: 99 times Was thanked: 5 time(s) in 5 post(s)
Guillaume and/or Maximus:
You guys are always right so i will be follouing your advice; but, for this one will you please explain the reasoning behind thhe recommendation.
Rob
DWAM wrote:I think it's better to have several hard disks - a small SSD for system only (120 or 240 GB) - another one for projects data (SSD or not 240/500 GB) - a large SSD for recordings 500/1000 GB
Guillaume Thanks, I have revised my system to include a 240GB SSD for system, and a 1TB for recordings. Am trying to get a 3rd SSD for projects.
Joined: 5/31/2017(UTC) Posts: 15 Location: Murray, KY
Your GPU link goes to an MSI 1060 6GB and not the EVGA 1060 6GB you mentioned.
Are you planning to use replay?
RHSportable wrote:Your GPU link goes to an MSI 1060 6GB and not the EVGA 1060 6GB you mentioned.
Are you planning to use replay? I am hoping to have replay ability. I built this system off the reference system Ruby, which does have 4 camera replay, I may need a slightly larger than 500gb SSD though in order to get replay.
Guillaume agree with a 240 GB SSD for operating system and a 240 GB SSD for all of the vmix project data and instant replay a 512 GB SSD for live recording plus a hard drive for backing up recordings etc
You have been a member since:: 4/23/2017(UTC) Posts: 1,484  Location: Germany Thanks: 3 times Was thanked: 197 time(s) in 177 post(s)
I would recommend taking a look at the CPU lanes. Most of the i7 only have 16 lanes. If you use a GPU with 16 lanes the PCIe bus is full. Adding a M2/PCIe HDD that uses 4 lanes as well could lead to some trouble or performance decreases. I recommend a 2011 socket with a Xeon CPU. The Xeons have smaller frequencies but compensate it with more cores and do have more lanes available. Just as a tip.
 1 user thanked mavik for this useful post.
mavik wrote:I would recommend taking a look at the CPU lanes. Most of the i7 only have 16 lanes. If you use a GPU with 16 lanes the PCIe bus is full. Adding a M2/PCIe HDD that uses 4 lanes as well could lead to some trouble or performance decreases. I recommend a 2011 socket with a Xeon CPU. The Xeons have smaller frequencies but compensate it with more cores and do have more lanes available. Just as a tip. That was a worry of mine, the CPU Lanes, but then I question why the CPU is in the Ruby reference system page, which states compatability for up to 8 cameras and replay. Between the GPU and I/O capture card, the PCIe Lanes are full, but why is this system in the reference system then? The Production Bot Switch 8 system has the same CPU and an 8 I/O capability, so I'm not sure how this works.
Spencerm24 The big bosses answered this question here https://forums.vmix.com/...aspx?g=posts&t=11946I have wondered about that issue also. 8 lanes of PCIE 3.0 apparently provides nearly 8.0 gigabites per second of bandwidth. Seems to me that more lanes is a good idea. Take this from a guy who still doesn't understand why multiple smaller M.2 drives is better than one big one!
Joined: 3/19/2017(UTC) Posts: 15 Location: Canary islands, ES
I'm a complete newbie in vMIx, in fact i'm just doing my first real production with it, and we've built a very similar system to yours.. Only noticeable difference:
Hard drives:
- 1x 250G for the system/titles/videos - 1x 2TB 7200rpm for recordings. - 1x 2TB SSD for instant replay.
Capture: Instead of the Quad 2 we decided for two Duo 2, because we did not want the hassle of the mini-din connectors.
As for the control system, we do have the AKAI APC40 Mk2 but we decided to include a 27' touchscreen, and it's really intuitive, If you dedicate some time to prepare the session beforehand you barely touch the keyboard or mouse during the live production.
I plan to write my impressions and upload some photos and videos of the production and build soon, once job is finished.
EDIT: Somebody commented on the limited airflow of a rack case. It was one of my main worries, since i live in a hot place and we work on very aggressive environments, so we decided for a liquid cooler for the CPU and a couple of 8mm fans on the back to push out the hot air of the 1060 and the capture cards. So far (4 days into an outdoor live production during a heat wave) and overheating has not been a problem
Joined: 8/31/2016(UTC) Posts: 15   Location: Little Rock, AR Thanks: 4 times
I want to build a very similar system but the only IO would be NDI. I want to use PTZoptics NDI cameras. Is it wise to only use NDI inputs for 3-4 cameras and vMix NDI Capture from a couple laptops? I have not seen anyone building a system without an SDI/HDMI input.
I'm curious as well regarding an "all NDI" camera system.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 588 times Was thanked: 202 time(s) in 168 post(s)
We build PC's running vMix frequently that have no capture cards where the client intends to either use all IP cameras or all NDI cameras. Typical limit for regular NDI is seven 1080p/30 video sources for one Gigabit network; about 100Mbps each. However, the current NDI cameras (NewTek and soon PTZ Optics) are NDI/HX which is a rather compressed version of NDI only requiring about 10Mbps per 1080p/30 video source.
So, yes, it has, can, and is being done.
- Tom
Guillaume Guys, it seems like everybody here agrees with Guillaume; however, I don't know why. It sounds like 1) windows and all software goes on a small fast ssd 2) video and stuff for your show goes on another which does not need to be ssd; and, 3) the show and any other multicorder recordings goes on a larger drive which does not need to be ssd And.....periodically the recordings are removed and backed up Is that it in a nutshell? It seems to me that the number two drive has the biggest load and if any is a ssd it should be that one. Any explaination or help is appreciated. Thanks P.S. i am sure Guillaume is right even though i don't quite understand.
The drive for being used for recordings would have the a greater load placed on it than drive #2. SSD drives have been recommended for recording with vMix for awhile.
Systems
