MrFreeze
#1 Posted : Wednesday, May 22, 2013 6:41:36 AM(UTC)
MrFreeze
Hi All
I'm currently building a computer system and I have 2 builds in mind.
One is AMD and the other is Intel.
Please don't start a "Intel is better then AMD" war.
The plan is to have 4 SDI inputs, one Flash overlay (for scores and such), and 3 vids/youtube sources. All are 1080P.
Both have 2 Backmagic DeckLink Duo. Infact the only difference is the CPU and Motherboard.
AMD System
Moth http://www.techbuy.com.au/p/201327/MOTHERBOARD_AMD_SOCKET_AM3_PLUS/ASUS/SABERTOOTH-990FX-R2.asp $221.75
CPU http://www.techbuy.com.au/p/207770/CPU_AM3PLUS/AMD/FD8350FRHKBOX.asp $250.1
SSD http://www.techbuy.com.au/p/210727/HDD_SOLID_STATE_DRIVES_-_IDE/Kingston/SV300S37A_60G.asp $93.45
Ram http://www.techbuy.com.au/p/164458/MEMORY_MEMORY_DDR-3_RAM/G.Skill/F3-12800CL8D-8GBRM.asp $85.25
case http://www.techbuy.com.au/p/40034/CASINGS_SERVER_-_4U/Antec/CSR-4U22ATX.asp $205.15
PSU http://www.techbuy.com.au/p/195358/POWERSUPPLIES_500W_-_599W/CoolerMaster/RS525-PCARD3.asp $73.35
GPU http://www.techbuy.com.au/p/207548/VIDEOCARDS_NVIDIA_GEFORCE_6_VIDEOCARDS/MSI/N650TI-1GD5OC.asp $168.25
total $1097.3
Intel System
Moth http://www.techbuy.com.au/p/195360/MOTHERBOARD_INTEL_SOCKET_1155/Intel/BOXDZ77RE75K.asp $283.35
CPU [url=SSD http://www.techbuy.com.au/p/210727/HDD_SOLID_STATE_DRIVES_-_IDE/Kingston/SV300S37A_60G.asp $93.45
total $1145.35
Thanks in advance
Grif
MrFreeze
#2 Posted : Wednesday, May 22, 2013 10:25:42 AM(UTC)
MrFreeze
