jsawyer77
#1 Posted : Tuesday, October 10, 2017 10:25:43 AM(UTC)
jsawyer77
HDMI and SDI card suggestion. We have four cameras and need a suggestion for cards as we often use them together. I see Blackmagic has a hdmi and SDI in one card. Does any one have experience with there deck-link 4K extreme cards? If so is it possible to have one SDI and one HDMI in running at the same time?
TIA
Josh
#2 Posted : Tuesday, October 10, 2017 12:03:22 PM(UTC)
Hi
AFAIK there are no cards with both HDMI and SDI inputs that you can use at the same time (except maybe the Aja IO devices on Thunderbolt > 1 HDMI + 3 SDI)
The best solution imho is to use SDI cards with HDMI2SDI converters. That's the cheapest way to do it and using SDI cables allows to use longer cables.
Guillaume
