Feature Requests
Shortcut to disable Web Browser Keyboard Control / new BrowserKeyPress shortcut
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
As it seems, I can not disable Web Browser Keyboard with shortcut. I need it badly, because I have developed web based graphics engine which works native in vMix Web Browser (currently using mouse to click buttons in preview), but now I'd like to forward button presses to Web Browser input (JS binds), to enable basically second set of shortcuts in Web Browser. I also need vMix shortcuts to work.
As I see, there are two options:
1. New shortcut named "BrowserKeyPress", works the same way as native "KeyPress" shortcut, but sends defined key only to Web Browser input. Or even "BrowserSendString" which is able to send certain commands/strings. For example "SelectName1", "ShowName", "ToggleL3rd", "ScoreBugOn" etc.
2. Enable some way to disable Keyboard via shortcut. It would be tidious to manage all shortcuts, since I'd need to create "BrowserKeyboardEnabled", then "KeyPress" and then "BrowserKeyboardDisabled" for every shortcut needed. But it would get the job done.
Feature Requests
