You have been a member since:: 12/6/2016(UTC) Posts: 5 Location: Syracuse
Is there a way to run automatically on power up?
Yes (sort off) I believe it has been addressed before in this forum
Go to the vMix folder in C: Programs, vMix, and copy the shortcut to this folder:"C:\Users\PC Name\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup"......restart your PC, and see what happens,....just wait a few seconds...vMix takes a short while after Windows does its stuff before it loads....
To further this thread a bit, is is also possible to enable streaming or recording automatically? Perhaps some command line params?
I don't think so...you have to setup the recorder, and furthermore, you have to open a program preset to have it load the inputs etc., before you can do anything ..... But you can setup triggers to record, stream, and other actions ....I use UTC as a trigger, then setup other things to trigger what I want....Check it in the Help section....https://www.vmix.com/help20/ (Activators - MIDI Lights and Faders)somewhere in that section......did not have time read exactly where...i seem to figure things out for myself.....
Maybe if we get enough requests for vMix team to make vMix automatically open and load the last preset, maybe, just maybe, we should be able to get that to work......
