He !
I'trying to connect a videocamera via the Pinnacle Dazzle. The card is being recognized by Windows 7 but can't be found in Vmix. I restarted the computer, but nothing works.
Update : Drivers reinstalled. Now it's being found in Vmix. But still no video : Capture Pin could not be found. What does it mean ??
Rgds, Daan
Joined: 1/13/2010(UTC) Posts: 5,373  Location: Gold Coast, Australia Was thanked: 4799 time(s) in 1647 post(s)
I've put in an update for the next version which should make vMix compatible with the Pinnacle Dazzle and other Pinnacle capture devices. The tricky thing is every manufacturer configures their drivers all just a little bit different, so I appreciate your feedback!
Thanks,
Ofcourse,
I like to help you with feedback. Any clue when I can expect the new version.
Is the error "Capture Pin could not be found" a known error ?. I use Windows 7
Rgds, Daan
He !
Is with the RC3 version the possiblity for Pinnacle Dazzle implemented ?
Rgds, Daan
Give RC3 a try and let me know, it should work.
Waiting for a new PC, so when I tried,I let you know
Rgds, Daan
Pinnacle Dazzle is working 100% !! Another USB input is also working great : Konig CMP-USBVG5
I'm trying to get video to come through the Pinnacle Dazzle from Sony video 8 tape.
I can get audio but not video. Weird.
Any idea of what resolution I should go with?
Martin Duffy
Duff, I think the Dazzle is SD only, so 480 or 576.....
