Feature Requests
Wishlist for new Shortcuts + Activators
Hi vMixers,
A wishlist of shortcuts and activators from observations during the last couple of weeks:
Activators: - ReplaySessionRecording (tells whether the replay module is currently recording) - ReplayDirection (could also be seperated into ReplayPlayingForward / ReplayPlayingBackward)
Shortcuts: - ReplayPlayAllEventsToOutput (Simply just play all events in the current replay bank to output) - InputVolume1 / InputVolume2 / InputVolumeX (control of audio volume for each channel for the audio input)
Best regards
Jens Stigaard
stigaard wrote:Hi vMixers,
Best regards
Jens Stigaard +1
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
Joined: 12/20/2016(UTC) Posts: 190   Location: Milano Was thanked: 21 time(s) in 13 post(s)
+1 and I add activator for "set transition effect"
Thanks: 211 times Was thanked: 13 time(s) in 12 post(s)
Joined: 10/8/2013(UTC) Posts: 45  Thanks: 4 times Was thanked: 6 time(s) in 5 post(s)
That would help a lot in our productions +1
Thanks: 8 times Was thanked: 8 time(s) in 7 post(s)
Joined: 12/3/2013(UTC) Posts: 17  Location: Netherlands Was thanked: 2 time(s) in 2 post(s)
+1
And I also would like to have the shortcuts ReplayPlayEventsByEventText and ReplayPlayEventsByEventTextToOutput. We are using shortcuts to tag each goal in a sports match, but also other event types. So then we can for example show all goals.
Joined: 3/12/2015(UTC) Posts: 482  Location: Kansas City, MO USA Thanks: 152 times Was thanked: 76 time(s) in 57 post(s)
+1 We have just received a JL Cooper ES-Slomo. It is very nice, if we can get all of these functions with the activator lights we will have a very nice replay box.
Steve
Joined: 10/1/2016(UTC) Posts: 117  Thanks: 88 times Was thanked: 52 time(s) in 31 post(s)
+1 Also adding an audio pan activator would be nice so we can map out all the controls on our digital desks or in OSC Touch. A few of the audio shortcuts do not have Activators, but i can't rember them all right now, I need to sit down behind our BCF2000 and xtouch to list all the missing ones. I remeber having no activators for all the busses last time I did some mapping.
Thanks: 4 times Was thanked: 13 time(s) in 4 post(s)
brian078 wrote: We are using shortcuts to tag each goal in a sports match, but also other event types. So then we can for example show all goals.
You can already do this with a tiny workaround: just type "goal" into the search bar next to the Events 8 tab and only events containing the word "goal" appear. Now just mark all events and press your shortcut-button for ReplayPlaySelectedEventsToOutput
Joined: 8/3/2015(UTC) Posts: 325 Location: Chicago, IL
+1 on ReplayAllEvents... that would be handy for me
Thanks: 8 times Was thanked: 6 time(s) in 6 post(s)
Joined: 4/22/2016(UTC) Posts: 83   Location: UK Thanks: 18 times Was thanked: 17 time(s) in 14 post(s)
Feature Requests
