NDI
VMIX17 DOES NOT SUPPORT NDI CONNECT SPARK !
I found that I can not find the NDI source for NDI Connect Spark in Vmix 17, but it works fine in vmix 20! can someone tell me how to fix it?
This is only a guess, but AFAIK the NDI Connect Spark requires a fairly recent version of the NDI support libraries (.DLL file). NDI-HX was introduced in NDI v3.0, only very recently, but I think there is support for detecting and using the Spark in later versions of the NDI v2.x DLLs from earlier this year. However, vMix v17 - which is 3 versions back - may have been using an even earlier version of NDI which simply does not work with the Connect Spark.
Joined: 3/30/2011(UTC) Posts: 311  Location: Portugal Thanks: 360 times Was thanked: 37 time(s) in 31 post(s)
vmix vintage 17 ???
who cares....??!! does not compute... bothering for old versions..... sorry....
Cheers,
PFBM
bh1054010 wrote:I found that I can not find the NDI source for NDI Connect Spark in Vmix 17, but it works fine in vmix 20! can someone tell me how to fix it? The fix is to upgrade the vMix version. Kane Peterson NewTek
 1 user thanked kane for this useful post.
Joined: 8/2/2013(UTC) Posts: 1,095   Location: Fairhope, Alabama USA Thanks: 587 times Was thanked: 202 time(s) in 168 post(s)
FYI, if you are using a cracked version of vMix, you can't always update. :(
- Tom
NDI
